VAC tractor
Old Bob
05-11-2008 07:30:30
I just bought a vac tractor. It needsa a battery. It is all original, but no battery, is it 6 or 12 volts? Thanks
Paul f
05-12-2008 05:38:36
 Re: Remeber Positive Ground in reply to Old Bob, 05-11-2008 07:30:30
If your VAC hasn't been modified it will be positive ground when you hook up your new battery. (To check look at your coil...if the + terminal wire goes to the distributor you have positive ground.
old
05-11-2008 08:14:30
 Re: VAC tractor in reply to Old Bob, 05-11-2008 07:30:30
When new it would have been 6 volts but it could have been changed to 12 volts. If it has generator its still probably 6 volts but if it has an alternator then it will be 12 volts
Mbkellogg7
05-11-2008 08:00:14
If it has a generator 6 volt. It came from the factory that way. I think that they were 6 volt regardless if it came with a generator or magento. Hope this helps.
Matt
Glenn F.
05-11-2008 07:58:20
My '54 VAC14 is 6 volt. I expect all VAC's are.
Glenn F.
Old Bob
05-11-2008 13:07:47
 Re: VAC tractor in reply to Glenn F., 05-11-2008 07:58:20
Thanks guys for your responses.
