Mowed with the SC today (it's been awhile)
Mike Schotte
05-10-2008 23:28:40
Mowed my place today- since I got the tractor running last week, I actually got to cancel the mower that I had hired to come by.
Bought a new tube for the front tire of the SC. You should have seen the guys face at the tire store- he did NOT want to mess with that 100lb. cast iron rim!
That's a really fun tire to try and hold up with one hand while trying to get the first bolt in. Whew.
Forgot to tie down the new battery and did my patented "spark the steering arm on the battery" trick. I'll never learn. At least I didn't weld the threads on the battery disconnect like last time! (I about never got that old wire off after that.)
The tractor ran great- but I may need to mess with the load screw on the carb. She didn't do as well on the tall grass as she used to. Either the carb or the governer weren't keeping up like normal... I had to make half passes with the brush hog instead of full passes.
The worst thing was that the muffler/stack kept throwing out hot rust pieces/sparks that were landing on my forearms. (yow!) Got a few blisters before it had run enough to shake all that crud loose.
Had a little bit of a radiator leak when I finished (this is the same radiator metal thieves tried to steal out of the tractor last year.) Couldn't find the leak, and the coolant level was still up. What worries me is that there seemed to be little oil drops floating in the coolant after mowing. The coolant wasn't milky- but I'm going to check the oil, too next time I'm out there. Crossing my fingers that all is O.K.
Hopefully the SC won't punish me for neglecting it!
-Schotte
Larry59
05-11-2008 20:59:13
 Re: Mowed with the SC today (it's been awhile) in reply to Mike Schotte, 05-10-2008 23:28:40
I got out and mowed a bit a couple of days ago. Enjoyed it but found the grass still a bit to wet and therefore it did not cut as well. Now when was last time you sharpen them blades? That makes a difference to.
I had to drop down from L-H-D shift to the L and used like second gear for it to pull right on my tractor in the wet grass.
Mike Schotte
05-11-2008 21:43:54
 Re: Mowed with the SC today (it's been awhile) in reply to Larry59, 05-11-2008 20:59:13
Hadn't thought of that Larry- I'm sure those blades haven't been sharpened in 20 years. I'm not sure that I could get them off of there if I wanted to!
Definitely not a job that I'd attempt by myself out there alone.
I just topped off the oil in the gear box and lubed up the U-joints and crossed my fingers that the grass juice and fire ant mounds would clear the rust and scale off the underside! (grin)
