case 411b
hank1949
05-09-2008 10:24:46
can not get hydrolics to lift then hold implement fluid leaks to different compartment of tractor if iadd more fluid it leaks out any help?thanks
Jim McVay
05-11-2008 14:25:01
 Re: case 411b in reply to hank1949, 05-09-2008 10:24:46
You can modernize it and machine the piston to accept a V-seal piston seal instead of the o-rings. The later cases use the V-seal. Pressure cause the seal to seal off better
dddl
05-09-2008 10:47:59
Had the same problem. Takes about 1-2 hours to fix. Pull your seat off, hitch arms and top plate of rock shaft (heavy thing). Replace the o-rings on the shaft and put back together. For a beginner i was antsy about tackling this but then the local machine shop was busy so i thought why not. Works fine now.
