Case 430 PTO turning
Amaranth Mike
05-09-2008 08:11:31
The PTO shaft in my "new" 430 will not fully turn off, even with a snowblower attached. You can tell that the lever partly disengages it, but it still turns. Is there any adjustment possible, or do I need to take out the PTO shaft assembly, etc? Thanks.
Don Rudolph
05-09-2008 20:39:45
 Re: Case 430 PTO turning in reply to Amaranth Mike, 05-09-2008 08:11:31
A Mike,
My 430 had the shaft turning all the time and it would not stop even when hooked up to the manure spreader shaft. We had to take it out and get some of the clutch disks replaced as they had gotten hot and warped. The previous owner must have let the clutches slip too much and they got hot. It cost $350.00 at the old Case dealer I like to deal with. Works great now. I love this little tractor. You aren't the Mike I used to know from Madison are you? Don
