Got out the new-used 6 ft Bee brush hog today.
Larry59
05-08-2008 19:36:49
Rain won't stop it seems very long. The grass is growning fast and hard. So I decided to get out the Brush hog I got recently. Had not tried it out yet and even being new to me only. I decided it was time to check it out. So hooked on to it and took it to a flat area so I could sharpen those two blades. Then added a bit of oil to gear housing on it and figured out that power shaft to the pto. Then off I went down the wet grass I went. Slow so I can get use to it. Never had one myself before!
It took off a humming like a bee in flight. Wonder if that is cause it's called the "Bee" ? Anyway I sure was proud making two long cuts in the field and then took it in for cover. More rain coming in now.
