Vac governor surging under load
young tractor
05-08-2008 10:20:56
I have a 1948 vac case with governor issues. When I purchased the tractor the governor function was basically non-existent. There was a lot of slopp in the swing arm and shaft. I replaced the balls and bearing and shaft. My question is that the governer reacts under load and surges and then backs off then surges and backs off. If you are plowing it will do this or going up a hill. I am happy that the governor reacts now, but how can I get it to react and stay there? It idles nice. I'm not sure if I have it running at wide open at high enough rpms. I don't have a tach, is there any good way to measure what the rpms are? Thanks for any help
Gene Dotson
05-08-2008 10:55:00
 Re: Vac governor surging under load in reply to young tractor, 05-08-2008 10:20:56
Check the governor to carburetor rod. With the engine off, open the throttle to wide open. Check the carburetor arm at the wide open stop. Shorten or lengthen the rod till you have 1/16 inch from stop... Gene
old
05-08-2008 10:45:57
If the main jet is set wrong or clogged it will also cause that problem. I would start by adjusting the main jet to see if #1 you can open it up to the point you get black smoke. If you can't do that then you have a clogged carb and that could well be the problem not the gov. its self. An engine that is running to lean will do just as yours is
young tractor
05-08-2008 11:01:36
 Re: Vac governor surging under load in reply to old, 05-08-2008 10:45:57
Thanks guys I will try both of your suggestions this weekend. I appreciate the help.
