SC wide front ballsocket bolts... size?
Crispin
05-08-2008 07:40:21
They're square head but mine miked up .560"-.600" in the shank. Are they 1/2" x 3" or 9/16" which isn't too common. Looks like heavy nuts as well.
What a great system Case had for changing them from the bottom with the tee slot and location bosses to hold all that stuff in place. I scratched my head for a bit looking down in from the top where there's no room to get in there. Thanks, C.
Crispin
05-09-2008 07:33:53
 9/16 square head it is... but not easy to find... in reply to Crispin, 05-08-2008 07:40:21
9/16" is not offered in square head with many companies: MSC, Jamestown, on-line, ect.
9/16" hex doesn't quite grab. I guess I'll weld a side on a hex bolt
C. Amick
05-09-2008 08:57:20
 Re: 9/16 square head it is... but not easy to find... in reply to Crispin, 05-09-2008 07:33:53
Can you find a heavy square washer or make a washer using a piece of square steel plate to slide on the bolt and weld to the bolt head? Might be easier than trying to build up the bolt head.
