SC Timing
Ken Christopher
05-08-2008 05:40:37
Ok, I went through every stroke very slowly cranking the engine over. Cam and crank (from what I can tell) are timed correctly. Governor is at 25 degrees with counter clockwise rotation when #1 is at TDC of the compression stroke. Also have the timing mark visible in the bellhousing at this point. Inserted the magneto. The magneto does have to be grounded to the tractor for the spark to stop doing the every other impulse trick. (Thanks Amick!) So I have that set to fire on #1. I cranked it over a couple times last night to see if it would fire, but after 2 attempts at 10PM I stopped because I don't think my neighbors would have liked an explosion if that was going to happen again. Also waiting on my oil pressure gauge line so I think I will wait on that before I try to give it another go. Just an update so far.
C. Amick
05-08-2008 19:19:07
 Re: SC Timing in reply to Ken Christopherson, 05-08-2008 05:40:37
If you need to turn the engine over slowly and don't have a crank, you can turn it at the belt pulley. You will need a 3/4" drive ratchet, with extension and a socket large enough to fit the belt pulley nut.
Mike Schotte
05-08-2008 14:17:17
I had to laugh when I read your every-other-impulse spark discovery with the ungrounded magneto.
I managed to light myself up this last weekend learning the same exact lesson... I'd already gotten the #1 spark and was rotating through the other cylinders. Shocked me right across the left thumb and forefinger.
No big deal normally- but here's where it gets funny: earlier in the day I'd been doing a lot of pinching and twisting with that hand while putting together a new 1/4" rubber fuel line and brass fittings. Got one of the worst & most painful hand cramps I'd ever had- my hand was like a claw that wouldn't open up.
Well guess what happened when I managed to shock myself across those same two fingers again? Stupid, stupid, stupid!!(grin)
-Schotte
c.hess
05-08-2008 13:52:52
Red an re read your posts.First it is important you look at fig 10 in manual Amick sent you. Internal timing very important. Than you need to mount mag in vise an put wire in no 1 position on mag . That is top right on mag looking at it from driver seat as mounted-than in vise put vice grip on lug on impulse-turn until you get a spark when impulse clicks(hold wire i/4 in from mag with insulated pliers somehow to avoid shock)when you have determined you just fired no 1 than carefully continue to turn until mag again clicks -this is no 3cyl continue turn again until mag clicks again no4 -continue again until mag clicks this is no 2 that just fired. Remove from vise an with tractor on itcompression stroke with pistion about 1/2 way up you should turn impulse coupling with fingers as far as possible -than groves on tractor should match an you can mount mag with top tilted close as possible to engine block-than turn flyweel with crank to dot on it than turn mag away from engine till impulse clicks an that should do it.
c.hess
05-08-2008 12:06:54
Remove all spark plugs -crank engine until you are sure no 1 cyl is approaching tdc on compression stroke-than have someone slowly turn engine with crank an when mag impulse clicks you should have spark on no 1 spark plug. Have plug grounded where you can see. Purpose of removing plugs is so if you have mag mounted wrong you dont break arm when it kicks back. Been there an almost had that happen. Ouch!!!!
Mike Schotte
05-08-2008 06:21:26
Good luck- sounds like you're on the right track...
