VAC will restore but should junk - One for Grandpa
Obession
05-07-2008 18:57:49
My grandfather bough it new a 1947 VAC case with an adjustable wide front. No eagle hitch.
The original�s tractor rear end is badly rusted out because a cattle salt lick block was left on the tractor for many years. The engine is stuck, tires flat and shot. PTO and clutch were also shot when it was parked inside 20 years ago. Sheet metal is OK.
The donor tractor is stuck too. No sheet metal or wheels. 2nd gear is out and it had the tall rims on it which my brother sold to a local case collector. It may have the wrong gear ratio for the short tires. I will have to take the transmission apart to replace 2nd gear in the donor tractor. I may also have to switch rear end gears from the other one to correct the gear ratio for the shorter tires. I do have a loose engine that I am going to steel out of a power unit for the tractor. The power plant has a live hydraulic pump on it and a PTO. Was that pump ever used on the tractors? Can I leave the live pump on the VAC and use it for something? Will the clutch fit in the tractor?
I am going to start restoring this VAC with an additional junk VAC tractor and make them into one. The tires are shot and I can't afford new rear tires. I own a couple of sets of used 14.9 28. I found a pair of blemish repair 13.6 28 Radial tires that are 60% for under $200 for the pair. Will these fit and look OK on the original 28 inch rims? I can�t find any 11.2 28 or 12.4 28 inch tires used. What were the original tire sizes for a VAC? I believe one of the tractors I have had the tall tires and the other have the short. What is a good manual?
Should I convert the tractor to a 12 volt alternator?
Any help would be appreciated.
loneranger27
05-07-2008 20:27:02
 Re: VAC will restore but should junk - One for Grandpa in reply to Obession, 05-07-2008 18:57:49
Please think about your options carefully. This is your grandfathers tractor. You can never get another tractor that he bought and used (most likely). I have a tractor from each of my grandfathers and one is in really rough shape, but I am going to rebuild it because of its history. Just my 2 cents worth.
Obession
05-08-2008 18:59:03
 Re: VAC will restore but should junk - One for Grandpa in reply to loneranger27, 05-07-2008 20:27:02
Thanks loneranger for the comment. TRUE STORY!! Back in 1948 --- My father who now has passed on remembered when they got the VAC new. My grandfather was our cutting hay with a team of horses. One of the horses was new and wild. My grandfather instructed his young boys to stay away from the new horse while he was cutting hay with the horses. My Father and uncle popped up in the hay field and accidentally spooked the horses. My grandfather got the horses under control and brought them into the barn. He made two hitch brackets and cut off the hitch to the hay mower and fitted the brackets. He hooked up the brand new VAC case and finished mowing the hay. This was the 1st use of the VAC and the last use of the horses.
In my lifetime(I am 32) I raked lots of hay and straw with the VAC. It ran our grain auger up until the early 90�s when the PTO went out. We used it to back wagons into the machine shed. It hauled many loads of manure with a wheel driven JD manure spreader. We used to have a wagon that my older brother pulled his four younger brothers and sisters around with. We used to even take it out on the frozen ponds and spin around in circles.
My Grandfather and Father have passed away. My uncle has advanced alzheimer's.
The VAC means a lot to me and my family so if anyone can answer my questions it would be appreciated.
Larry59
05-07-2008 19:46:39
I hope you have a lot of time on your hands are years to do all that in. For sometimes I feel things can get much to costly and one can never ever get their money back they spend just on parts. Time you spend all that money on it. You could have bought one running and in better condition for much less then spent. As for labor of hours spent on it. Lets say in some cases you will not make one cent labor to yourself time all done.
Some will say go ahead and do it. But then they are not doing that much to an old tractor. Those like that,they park outback and sale parts of it!
I am not trying to be a smart a$$ but like a friend of mine does at times. Park it out back and sale parts. Get one a bit better condition. Same make and model even you can fine and be happy down the line.
TimBinWV
05-07-2008 19:45:40
I have a 48 (I bvelieve) that I took the engine off of to put on my 54 VAC-14 that I'd be willing to trade on the power unit.I have the engine off the 54 but it's apart,needsa a kit. Email is open,if you're anywhere near WV
Obession
05-07-2008 19:50:15
 Re: VAC will restore but should junk - One for Grandpa in reply to TimBinWV, 05-07-2008 19:45:40
Minnesota
TimBinWV
05-07-2008 20:09:28
 Re: VAC will restore but should junk - One for Grandpa in reply to Obession, 05-07-2008 19:50:15
Are you sure the engine is the same on the power unit? The VAC used a 124 cu inch engine,and the 300 series used a 148 cu inch. The blocks look the same,but the 148 is 3/8 ths of an inch longer.
Obession
05-07-2008 20:16:04
 Re: VAC will restore but should junk - One for Grandpa in reply to TimBinWV, 05-07-2008 20:09:28
Not 100% sure. How do I tell? Where do I measure?
Are there any numbers or data plates?
Can I make to hood longer and use the 300 engine?
Thanks
TimBinWV
05-08-2008 04:01:42
 Re: VAC will restore but should junk - One for Grandpa in reply to Obession, 05-07-2008 20:16:04
Measure from the rear flange to the front of the block,if itr's 19 1/4 or thereabouts,it's a 124. If it's closer to 19 1/2 it's possibly a 148. They also made a 126 cu. inch engine that looks like them,and put it in the 200b series tractors.
TimBinWV
05-07-2008 20:05:58
I hate to see a powwer unit disassembled....I'd like to have it for my "collection"...
I'm fairly new to Case's but I have 3 I really like,a '54 VAC-14,a '58 310b w/loader and forklift and a '58 311b w/triple-range transmission. Plus the parts tractor.
