SC magneto timing
Ken Christopher
05-07-2008 05:34:41
Ok, Now that I believe I got the crank and cam in time together, I know I have asked this at least five times. But the magneto seems to fire every other impulse, so, basically, I need to know at what position does the rotor need to be at for it to fire at #1. someone told me before to take the cap off and look at the position of the rotor. I know about as much about magnetos as I do about rocket science. Very little. But, I know there is a flange like piece on the back of the rotor. Is that supposed to point towards whichever cylinder is supposed to fire? Pictures would be helpful, but not necessary. Thanks again fellas!
C. Amick
05-07-2008 09:21:34
 Re: SC magneto timing in reply to Ken Christopherson, 05-07-2008 05:34:41
Does this help? See link below.
Mike Schotte
05-07-2008 10:37:24
 Re: SC magneto timing in reply to C. Amick, 05-07-2008 09:21:34
Ooooh.... very nice Mr. Amick.
Thanks for the link- I hadn't seen those manual scans before.
Of course, without new Case mag parts, it's all academic, right? (grin)
I might be wrong, but I don't forsee anyone remaking those interleaved coils in the near future!
C. Amick
05-07-2008 09:07:57
This may not be the answer to your question, but the magneto should fire with Cylinder No. 1 (front cylinder) on the compression stroke (about a 1/2" before top dead center) and with the flywheel punch mark visible through the inspection hole in the bell housing. I guess you could hook spark plugs to the magneto leads in order to determine for sure which cylinder it is firing on and adjust the rotor position from there? The spark plug body probably needs to be grounded to the engine block.
