what color should our tractor be?
hiwayman
05-06-2008 19:43:33
What is the correct color for a '35 model "L" case. the one we just bought is gray(silver), with red lettering. also, the hand clutch won't stay engaged. how tuff is it to adjust. my arm gets tired tryin to hold it back.
hiwayman
05-09-2008 17:09:47
 Re: what color should our tractor be? in reply to hiwayman, 05-06-2008 19:43:33
thanks a bunch for your help, walt. i really appreciate the info on the clutch. we just got this case a couple of weeks ago. it was listed as a restoration, but actually was just painted and had some decals slapped on. but it started right up after sitting for about ten years, so we"re pretty happy with it. it"ll probably just be driven in parades, but who knows we mite use it as a garden tractor!! thanx again!!
Walt davies
05-06-2008 22:06:32
Those colors sound correct.
To adjust the clutch open the side panel on the clutch housing you will find a small pint on the back of the clutch pressure plate pull it back so that the plate will turn on the shaft.. I would back it off i think its to tight. it should snap over and then hold the engine without slipping.
Walt
PS You might want to get a good Case service manual to help you.
Walt davies
05-07-2008 08:09:21
 Re: what color should our tractor be? in reply to Walt davies, 05-06-2008 22:06:32
This is from another book of mine it is the correct colors for an L.
Walt
third party image
Walt davies
05-07-2008 07:53:19
This is from my LA book it should be close to the L.
Walt
third party image
