dc case
tooltime
05-06-2008 15:34:06
i sent the head to machine shop to check everything out, the machine shop was wondering what size engine this head came off-- i told him it was a 1950 , but was not sure of engine displacement, does anybody know the size- cubic inch motor this dc tractor has. thanks, Jim
Gene Dotson
05-06-2008 18:27:34
 Re: dc case in reply to tooltime, 05-06-2008 15:34:06
Would be a 259 with 3 7/8 bore and 276 with 4 inch bore... Gene
tooltime
05-06-2008 18:37:40
 Re: dc case in reply to Gene Dotson, 05-06-2008 18:27:34
how can i measure to tell if my engine has been bored to 4'' i dont think it has been over hauled before
garytomaszewski
05-06-2008 18:53:04
 Re: dc case in reply to tooltime, 05-06-2008 18:37:40
Simple stuff, the bore is the diameter of the piston "hole", so lay a ruler across the sleeve(where the piston fits) and measure. Or you can get fancy and get a caliper or divider; stick it in the bore open to its widest then take it out and lay the points on a ruler, either way you should not have a problem telling if it is 3 7/8 or 4 inch "bore"
zach in neb
05-06-2008 16:01:50
i think the dc engines are 260 cubic inches
tooltime
05-06-2008 17:43:22
 Re: dc case in reply to zach in neb, 05-06-2008 16:01:50
thanks zach,Jim
