Case 580D -sitting unused for 2 years. What to expect?
paul c
05-06-2008 07:32:27
What would be the expensive repair items I need to consider before buying a 580D that has been sitting unused for 2 years?
Larry59
05-07-2008 20:16:00
 Re: Case 580D -sitting unused for 2 years. What to expect? in reply to paul c, 05-06-2008 07:32:27
First if they say it did run and you belive this person. Then pull the plugs and fill with tranmission fluid each cylinder and let it set for one to two weeks. This losens up the rings on pistons and most time frees them. Then try to turn it over with starter. If it don't move ok stop and don't keep trying. Let it set more to free it. In the mean time take off starter and jump it off tractor to see it turns over real good. Once the motor does turn over good. Then you go to fuel and fire of tractor. Oh besure and if tractor turns over. Let it pump the fluid out of cylinders good. Then change oil and filter on it. Filter could be stopped up and not let the oil pump threw. Could lose an oil pump then. Do not pull tractor to try and start it with out motor being free. Lots of damage can come from doing that.
