Is the wide front pin parallel to the Earth?...
Crispin
05-06-2008 05:41:58
I got the pedestal out last night and am now faced with restoring the geometery.
Is the center pin exactly level with the tractor and 90 degrees to the king pins? Are the king pins exactly verticle?
I have some pictures that I"ll try to get up. Thanks, C.
C. Amick
05-06-2008 09:18:48
 Re: Is the wide front pin parallel to the Earth?... in reply to Crispin, 05-06-2008 05:41:58
Yes, there is a slight tilt toward the front for the king pins. Mine had a lot more tilt than it should have when I got it. Check the ball and socket that is up under the belly of the tractor for wear. It could be contributing to the tilt. I had to make a new socket for mine. Also I had to replace most of the frame bolts. They were loose and also contributed to the tilt.
Crispin
05-06-2008 09:03:42
 Or is there some forward rake? in reply to Crispin, 05-06-2008 05:41:58
I need to set this up for machining. The pedestal casting looks like it has a slight angle that would give the king pins a little forward rake or to put it another way, the pivot pin is angled up at the front a few degrees. This would put the top of the king pins back a hair from the bottoms rather than truly vertical. This would make the cross beam of the wide front not exactly vertical but tipped back a little at the top.
Please help so I can decide whether or not to pursue a salvaged pedestal, weld this one or what to do... Thanks, C.
Old Iron Larry
05-06-2008 16:30:32
 Re: Or is there some forward rake? in reply to Crispin, 05-06-2008 09:03:42
I have just finished rebuilding a wide front for a DC which is the same as yours. I had to have my center rebushed. The hole is sguare with the center axle section and angled up slightly in the front bolster. I will have some pictures of mine on tomorrow night.
Crispin
05-07-2008 07:24:07
 What about fore and aft play? in reply to Old Iron Larry, 05-06-2008 16:30:32
The yoke has about a 2" gap and the axle beam is about 1 5/8". In my parts manual, I don't see bushings or washers for that gap. The ball and socket should locate the axle but I still wondered about the extra space in there. Thanks, C.
Old Iron Larry
05-07-2008 16:14:38
 Re: What about fore and aft play? in reply to Crispin, 05-07-2008 07:24:07
I just used machine bushings to tighten mine up.
