case 1190
justdan72
05-04-2008 16:25:05
hi i have a chance to buy a case 1190 , the clutch is slipping , so iam wondering if there is an ajustment for these ? or how much and where i could find a clucth ect for it ? also anything i should look for when i go see it ? pretty good deal at 2500 , thanks for all your help Tim
Edpap
05-04-2008 18:33:44
 Re: case 1190 in reply to justdan72, 05-04-2008 16:25:05
Hello Tim,
check the free play on the clutch pedal. it should be around one inch. if you have none it could just be an adjustment. if the cluch is bad a new one with bearings and a PTO disk is around $750. it is a two stage clutch so they are a little pricey. I am showing a 10 inch or a 12 inch clutch for that tractor.
another thing to look at is how the engine starts when it is cold. if it has to crank alot there might be some problems.
I work on alot of david brown tractors I think they aren't to bad but some guys say to stay away from them.
I would say that the price is right.
Good Luck Ed
