What did I just buy
megamc
05-03-2008 13:39:02
I just bought a Case tractor without the ID plate on the dash. I think it"s a late 40"s. It is an orchard model, has square front and rear axles,a wide front. A 4 speed trans with the stick shift bent. Electric start, 6.0-16 front and 11.2-28 rear tires. No pto and no hydraulics. Apparently no muffler and no oil filter that I can find. What model is it?
megamc
05-03-2008 20:24:09
 Re: What did I just buy in reply to megamc, 05-03-2008 13:39:02
An oblong flange is attached to the exhaust manifold and is directed down but is only about 6-8 inches long.
Joe (Wa)
05-04-2008 03:07:36
 Re: What did I just buy in reply to megamc, 05-03-2008 20:24:09
That is a factory elbow used where a muffler is not practical, I.E. vertical exhaust overhead clearance (limbs) or underslung exhaust (grass fire). P/n is VT220.
Joe
TimBinWV
05-03-2008 18:33:36
Does the exhaust run down from the manifold?
TimBinWV
05-03-2008 18:33:13
Does the exhaust run down from the masnifold?
C. Amick
05-03-2008 16:29:43
Look in the tractor photos on this web site to see if you can find one like it. I think the VAO should have 15 inch front tires and I wouldn't describe the front as square???
TimBinWV
05-03-2008 18:30:12
 Re: What did I just buy in reply to C. Amick, 05-03-2008 16:29:43
I understood him to say square front axle,C Amick. The VAO would have had a square solid front axle,no? The front rims could have been replaced with 16" also.
C. Amick
05-03-2008 20:58:07
 Re: What did I just buy in reply to TimBinWV, 05-03-2008 18:30:12
Oh!! I need new glasses.
TimBinWV
05-03-2008 16:17:58
Scant description,but it sounds like a VAO. Round nose?
