magneto to distributor
T.Timko
05-03-2008 12:58:35
what do I need to switch my 53 DC from magneto to distributor?
dboll
05-05-2008 12:16:38
 Re: magneto to distributor in reply to T.Timko, 05-03-2008 12:58:35
for those of you who are adamant on running mags please advise the rest of us what to do about 90% of the mags that have bad coils ( I have around 30or 40 type 41 and jma mags) I do have some good running ones but for regular users or on pullers I like distributors, as mentioned for parts availability and mechanical spark advance
Paul f
05-04-2008 07:11:22
A delco remy model 1111411 right angle distributor works well
Jim McVay
05-03-2008 20:50:35
A IH or AC distributor with a flange mount should work. Just bolt it on install a coil and wire it up.
CWH
05-03-2008 14:43:23
Why do you want to do that??
Paul f
05-04-2008 07:20:51
 Re: magneto to distributor in reply to CWH, 05-03-2008 14:43:23
Well for one reason if you have a dead mag a rebuilt one is well over $200 (more like $250) and then if something goes wrong with it you have to try to find parts.
For $35 you can pick up a distributor at a salvage yard, stop by the auto parts store on the way home and pick up points, condenser, rotor and cap for $25 add a coil for another 25 and you have a reliable system that can be easily/quickly fixed. Heck throw in new wires for $15 and you still are just at $100 vs 200-250
The big advantage of a mag is not needing a battery but since most of us do not routinely start our tractors with the hand crank I am not sure how important that advantage is.
CWH
05-04-2008 22:59:48
 Re: magneto to distributor in reply to Paul f, 05-04-2008 07:20:51
What you say is true assuming that the mag is bad (bad to the point that just replacing the points, condenser, etc. will not help). Another option is converting the mag to distributer ignition. Yes it can be done, at least on Case 4-JMA mags. I've just gotten rid of one that had been converted. (Check with John Saeli).
