SC timing
Ken Christopher
05-03-2008 06:42:26
Ok, so I got everything pulled apart again. Should be able to re-use the timing cover and oil pan gaskets. Governor and water pump gaskets are ripped, but I think I will just use some RTV for that. Now here is the thing. I got everything apart, and the cam and crank were in time according to the punch marks. So I am thinking maybe just the governor was out of time? I am trying to do this as slowly as possible so I know that I have it right. Here is my next issue that I think I might have. When I tore everything apart (I know I will hear it for this) I did not mark the stud to the flywheel when I pulled the crank and flywheel apart. I am wondering if I also have the flywheel turned one stud forward or back. So the timing mark does not line up quite right. I have not done enough investigating with that yet to know for sure. I played with it for 20 minutes before I had to come to work this morning. All that should matter though is I get #1 at TDC of the compression stroke with the magneto/governor at 25 degrees if I am correct?
L.Lamp
05-03-2008 18:44:56
 Re: SC timing in reply to Ken Christopherson, 05-03-2008 06:42:26
I have put 6 SC engines back together in the last 6 years. I followed the directions for all the timing marks, so I know everything is correct with all the timing gears. The head is not on when I time the engine so I don't know if #1 is on compression or not. Both #1 and #4 are both up, one on compression the other on exhaust. I do not think you can have an issue with the flywheel either, because the engines I have worked on, the flywheel will only go on one way. The bolt holes will not line up unless it is in the proper position. Since you do not know where the mate marks are for your governor gear, turn the engine to top dead center. Take the little plug out of the bell housing near the starter and line up the little drilled hole in the flywheel in the center of the plug hole. When you have done that, pull the governor gear, turn the magneto drive lug counter clockwise so the lowest lug is tword the engine and at 25 degrees past level. Insert the governor. If the gear mesh causes it to change, remove and reinsert till you get your 25 degrees. At this point it will fire on #1 or #4. Now if the intake and exhaust valves for #1 OR #4 cylinder are both closed with play on rockers that is the cylinder that is ready to fire. Turn the mag until #1 fires when both valves are closed for that cylinder. The firing order is 1,3,4,2. If both #4 valves are closed, turn the mag till #4 fires. Use a spark plug wire in the #1 or #4 position and observe the spark jumping to the mag case if held 3/8 to 1/2" from the case. Do not turm the mag any further after determining which cylinder you want to fire first. Let the mag dogs turn counter clockwise enough to allow the mag to be inserted into the drive dogs and for the mag to fit up nicely to the governor housing. At this point you know which cylinder will fire first. Insert the rest of the wires in CLOCKWISE order from the wire number you started with, 1342 for #1 and 4213 from #4 because the rotor reverses direction inside of the mag and turns in the opposite direction the mag is turned by the governor gear. Your tractor should now start and run fairly well. Stop it and turn the engine over by hand to see if the little hole is centered in the bell housing hole when the mag clicks. Take the spark plug wires off the plugs when you do this. When the magneto clicks and the flywheel hole is below the timing plug hole the mag is firing too early. Move the top of the mag towards the engine to retard the spark and away to advance it. You now have a perfectly timed SC. Remember everybody, if you have matched up the timing marks and your tractor does not start, but backfires, just move the spark plug wires clockwise 1/2 a turn on the distributer cap. It works for me!! Good luck!
Bob DeVol
05-03-2008 08:13:56
OK -lineup the punch marks on gov-gear as per other post-recheck marks on cam and crank gears!Now pull #1 spark plug and the valve cover- turn the engine over (in the direction it runs) and watch the valves. when you see the intake open contiue on till it closes at this point look into #1 cylinder and watch piston come the very top stop turning. may need a flash light to see inside. at this point you are at top dead center (TDC). now find # 2 wire on the mag - install the mag turning the mag drive coupling as needed untill the slot lines up( in the direction the mag is driven) contiue to turn mag untill #1 fires STOP tighten mag bolts. Should run if it's got fuel and compression ! May have to fine tune timing after it is running. Don't worry about the fly wheel marks- there are alot of S-SC-SO s that aren't where they should be.
