SC head - Fixable??
patsdeere
05-02-2008 15:36:12
I got my head back from the machine shop and it has some serious issues. It seems the inlet tubes both have spots where they have rusted out. Each tube has 2 or 3 holes slightly bigger than a BB. I was wondering if I just jb weld the living daylights out of the holes and then bore it out slightly smaller, would that work? I am not going to be doing anything fancy with it, just a few parades and a show here or there. No work for it. I would rather save it if I could since I already plunked down a large chunk of change and have nothing to show for it (other than a fancy looking boat anchor - according to the machinist).
What is on the back side of the inlet tube? Is it water or exhaust gas?
Thanks.
jjamna
05-04-2008 19:36:30
 Re: SC head - Fixable?? in reply to patsdeere, 05-02-2008 15:36:12
I have one that came off a running tractor however, it will need new seats and guides, valves ect ect. You can have it for cheap plus shipping. Drop me an email if interested.
mEl
05-03-2008 04:42:49
We did a DC head for pulling , for bigger intake ports we bored the intake runners out to water then made thin metal sleeves and treated them with Devcon and pressed them in the runner. After many years we are still useing this head. Never leaked one drop of AF and we keep the engine filled all the time. mEl
C. Amick
05-02-2008 19:08:48
Are the holes on the face where the manifold gasket seals?
patsdeere
05-02-2008 20:50:58
 Re: SC head - Fixable?? in reply to C. Amick, 05-02-2008 19:08:48
No they are about an inch into the head.
garytomaszewski
05-02-2008 17:50:39
What is an inlet tube ? The metal rings that go to the intake manifold are just insurance against leaks and mis matched gasket/manifold. We have run one on same duty for years without them.
patsdeere
05-02-2008 18:46:52
 Re: SC head - Fixable?? in reply to garytomaszewski, 05-02-2008 17:50:39
I understand that. The holes are actually where the air gets sucked into the head on the way to the valves. I was wondering if I used JB weld if there would be a problem with heat destroying it over time or if there was just water it might just work and keep the water out of the air inlet.
