case 800 converter clutch pump
James Pollard
05-02-2008 11:34:42
Hello I was hoping someone may know what type of bushings are in the converter transmission pump. Its a case 801b caseomatic.I have had the pump out when I changed fluid. Noticed it had some play . I put it back in hoping a change of fluids and a new filter would help get operation of converter working.NO luck In parts breakdown it says housing and bushing . thanks for any info.
JamesPollard
05-04-2008 06:14:30
 Re: case 800 converter clutch pump in reply to James Pollard, 05-02-2008 11:34:42
Thanks Gary for the specs. I only have access to parts breakdown on the web. Can't afford a manual yet. I took apart pump. replaced bushings and lapped the back cover. Pump is now putting clutch pressure in high green. Problem when I press on clutch pressure drops down to u in clutch on gauge. When released pressure goes right back to green in gear or out.If any ideas on what would be the cause of the specific ailment. I did pull clutch control and found that the inner spring was missing and a washer that goes between piston and spring was placed between large threaded plug and piston. not doing anything. Anyone have any ideas please chime in. Thanks
Gary Smith
05-05-2008 06:17:17
 Re: case 800 converter clutch pump in reply to JamesPollard, 05-04-2008 06:14:30
In reply to the preasure droping when clutch is disengauged. This is normal. You are opening the preasure valve and oil is bypassing back to the converter housing.
Gary
JamesPollard
05-05-2008 16:08:07
 Re: case 800 converter clutch pump in reply to Gary Smith, 05-05-2008 06:17:17
thanks Gary appreciate you taking the time to help me out. James
Gary Smith
05-02-2008 19:57:33
My manual says that the COM pump should have 190 to 220 PSI at 1500 RPM. Clutch engaged. This is taken from the pump housing just above the oil filter on the right side of the tractor. The clutch preasure should be 160 to 170 PSI at 1500 RPM. At 600 RPM the preasure should not vary more than 20 PSI over the reading taken at 1500 RPM. This reading is taken from the clutch housing on left side of tractor where small line goes to gauge on inst. panel. The converter preasure should be 35 to 45 PSI at 1500 RPM. This is checked from the side of the clutch housing. There is a small pipe plug there. The regulator valve on your COM pump can be bad. I had that happen once. The worst case is if the tolerences in the converter are getting large too much oil slips by things inside. I had that happen once.
Gary
comfortking
05-02-2008 12:31:46
Check the pressure relief valve on the pump you took out. Make sure the plunger is free and unbroken. I have seen several of these valves cause problems, I have not seen many pumps wear out.
James Pollard
05-02-2008 13:16:14
 Re: case 800 converter clutch pump in reply to comfortking, 05-02-2008 12:31:46
thanks comfortking. checked valve. is functioning but using air pressure it does leak air pressure thru relief holes. Not sure if it is suppose to but unlike an air relief valve it does have leakage. I took pump apart and bushings and shaft show wear. I have pressure on the instrument gaauge but needle only reaches the letter U not the green. When I press on clutch I loose pressure until I am running in what I assume is direct drive. The farmer who I bought this off of for 1000. said he has used it this way for the last 5 and has owned it for 25. I am paying 50 a month so if I don't get it running as its suppose I still have it to run as a power unit off the pto and pull my wagon to the scrap yard. thanks for any other suggestion I have search the archives for a while before posting my questions. Caseomatic is a bit of a mystery it seems .
