Need magneto parts for 53 dc
T Timko
05-02-2008 06:32:21
I would like to know where I can get cap, rotor, points and coil for my tractor.
C. Amick
05-02-2008 09:09:20
 Re: Need magneto parts for 53 dc in reply to T Timko, 05-02-2008 06:32:21
Do you still have a magneto or has someone converted to a distributor type ignition system? If it's a distributor, one that sits vertical is probably a Delco and one that sits horizontal is probably an IH. If it's a magneto, does it have a Case Eagle symbol on it and a removable cover on top?
TTimko
05-02-2008 15:23:07
 Re: Need magneto parts for 53 dc in reply to C. Amick, 05-02-2008 09:09:20
Yes it has the eagle and removeable top
C. Amick
05-02-2008 17:23:16
 Re: Need magneto parts for 53 dc in reply to TTimko, 05-02-2008 15:23:07
Replacement parts for Case magnetos are scarce. There's a coil up for auction on Ebay, see link below. Thee is no guarantee that this coil works, however. John Saeli ([email protected])sells remanufacturered working magnetos for $225, if you want to go that route and keep your tractor as original as possible. If you aren't concerned about originallity, you can put a used IH or Delco distributor on it for less money.
El Toro
05-02-2008 08:53:32
Try Standard Magneto at 1-800-MAGNETO. Hal
nebraska kirk
05-02-2008 07:38:58
If you can tell me what make and model of magneto is on your DC, I will look through my sources and see if I can find you some.
