C vs. CC gearing
mshultz
05-01-2008 17:37:07
Is there a difference? I had both rear covers of mine a few weeks ago and counted teeth on the bowl sprocket, and they both had the same number of teeth (34 if I remember right) - I was guessing that would be where the difference was. I wasn't able to count front teeth, and didn't bother counting teeth on the different gears to compare. Just curious to know if there's a difference. I assumed since the CC had bigger tires that it would be geared a little slower to have about the same ground speed as a C.
Thanks!
Chances R
05-02-2008 06:40:55
 Re: C vs. CC gearing in reply to mshultz, 05-01-2008 17:37:07
I can tell you that the C series which would include the CC could be ordered with different sprockets that would change the speeds. Industrial units often had the faster sprockets. Tire size will very much change the speeds. You can tell this by the circumfrence of the tire. A taller taller will run a tractor much fast. The CC would be faster assuming they had the same sprockets as the C.
