Need help with IDing VAC tranny housing
Farmer Jack
05-01-2008 14:36:04
I have a late model VAC with the worm gear steering and band brakes. The transmission case has a broken flange where it mounts to the axle housing and needs to be replaced. I think it is casting # VT561 (or VT567). I found one case in a salvage yard with the number VT596. I need to know if this will work and/or what other casting numbers will work.
Thanks for your help.
TimBinWV
05-01-2008 16:25:42
 Re: Need help with IDing VAC tranny housing in reply to Farmer Jack, 05-01-2008 14:36:04
Hey,Farmer...you near WV?
Farmer Jack
05-01-2008 16:33:28
 Re: Need help with IDing VAC tranny housing in reply to TimBinWV, 05-01-2008 16:25:42
I am in IA near Ames
TimBinWV
05-01-2008 16:36:38
 Re: Need help with IDing VAC tranny housing in reply to Farmer Jack, 05-01-2008 16:33:28
I've got a VAC for parts,but it's in WV...not worth the gas to come and get it...
Joe (Wa)
05-01-2008 15:33:37
P/n VT567 is an adapter used on a side mounted hydraulic control valve.
Casting # VT596 is a torque tube casting nr, see the tractor ID post just below this one.
Casting # VT241 - case, transmission (use VTA466).
VTA466 - case, transmission (VAC tractors before #5455000 and VAC tractors 54555000 to 5555000, VA and VAO tractors before #5555000 with disk type brakes).
Casting # VT561 - case, transmission (use VTA2818).
VTA2818 - case, transmission (VAC tractors #5455000 to #5455500, VAC, VA, and VAO tractors after #5554999 with band type brakes).
Casting # VT696 - case, transmission (use VTA3296).
VTA3296 - case, transmission (VAC-14 only).
Joe
