how to clean up tractor for painting
tooltime
04-30-2008 15:01:45
i would like to paint my dc case tractor. i do not want to sandblast. whats a good method to try cleanup the grease and prep the metal for painting... any ideas? thanks, Jim
El Toro
05-01-2008 16:09:38
 Re: how to clean up tractor for painting in reply to tooltime, 04-30-2008 15:01:45
A good steam jenny would remove that grease and dirt. Hal
C. Amick
05-01-2008 07:04:10
I am told that this stuff is a really good degreaser/cleaner, see link below.
tooltime
04-30-2008 17:40:35
Thanks everyone. its all good advice . I will probably try a little of all you said to do, and see what happens. ill send pictures when done painting, Thanks. Jim
Den N Ms
04-30-2008 16:40:09
It works goodIf you can find some lye,Zanes recipe You can make a good, effecient and cheap paint remover by combineing Red Devil lye, corn starch and water.
Ad the corn starch to the water FIRST till it has colored the water as if it were milk. Then while stiring the water and starch slowly add the red devil lye untill you have a consistensy of gravy.
Apply it to the tractor to remove paint and or grease with a paint brush.Let it set for as long as you like but don't let it dry out.You can use water from your garden hose to wash away the disolved paint and grease.Use as many treatments as necessary to remove all the paint and grease that you desire.
DO NOT GET IT ON YOURSELF AS IT IS COSTIC LIKE ANY OTHER PAINT REMOVER. ALWAYS WEAR SAFETY GLASSES.If you should get it on you and it begins to burn you should flood with water.Vinigar will neutralize it after you have finished cleaning the tractor.
This is a very econimacal way to remove paint and grease.
By the way, it will also remove rust!
Just be sure to flush the area you used it on with vineger and water before painting.
Jim McVay
04-30-2008 16:13:25
We knockoff all the old paint with a needle scaler. It takes it down to the bare metal and then use X-14 whitewall cleaner and a pressure cleaner to get it ready.
Glenn F.
04-30-2008 15:36:06
Oven cleaner, spray off, high pressure air, a putty knife and screwdriver....It aint no five minute job, but that DC's worth it!
Glenn F.
