egale hitch
dk
04-30-2008 06:51:19
the 800 case i have has a egale hitch. what kind of plows and disk can i hook up with it. all equipment i have won't fit. help
Larry59
05-03-2008 17:51:31
 Re: egale hitch in reply to dk, 04-30-2008 06:51:19
I agree with the others who posted. Move the pins is all it takes at times. Sometimes just one or move both endward or outward. I have no problems with my Eagle hitch anytime. I just moved pins to fit.
Larry59
05-03-2008 17:51:17
C. Amick
05-01-2008 19:25:32
On my 300 I turned one of the pins of the rotary mower to the inside and got it to work. On my home-made bale carrier I have a horizontal rod that goes all the way across and I just snap the Eagle Hitch arms onto the rod. With some implements, I've been using a longer center arm than the one that came with the Eagle Hitch.
Bret4207
04-30-2008 12:53:11
Most 3 pt stuff will fit. Sometimes you have to turn the 3 pt pins around or use bolts or make an adapter. The only big problem I have with my 811b is using a bale spear, it doesn't lift high enough.
