430 case 3 point
jimmy treat
04-30-2008 06:12:21
I just purchased a 1967 D430 case tractor and the 3 point will go up but won'come down. Is it a pressure up and down or free fall down? I have taken the control valve off and with the lines disconnected the 3 point still stays in the up position. Any help will be greatly appreciated. Thanks Jimmy
J Heitkemper
05-01-2008 20:02:54
 Re: 430 case 3 point in reply to jimmy treat, 04-30-2008 06:12:21
Hi Guys , After putting a hydro piston seal kit in our 430, sometimes the arms will not come down unless I hook a chain to a post and nudge it down ,, This one here is very tight .. Best Regards , Jim
Duane(Pa)
04-30-2008 12:37:18
I have a 430 gas, it free falls down. (no pressure down)There is a rate control screw in the block beside the control handle, if its bottomed out, in may not come down at all?
jimmy treat
05-01-2008 18:14:08
 Re: 430 case 3 point in reply to Duane(Pa), 04-30-2008 12:37:18
Thank you for the information. One more question, is there any place to get parts for the 430's that you know of? I am just starting and really not up to speed yet. I have ordered a manual and should be here next week. Again thanks.... Jimmy Treat
