SC Timing-Back to Basics
Ken Christopher
04-29-2008 05:43:02
Ok, well, here is the scoop on my SC. I have had it all abck together for a while. Primed. Just have been waiting for it to get a little warmer here to try to test run it.
Got it all ready. Hooked up all my lines/wires. Poured in fluids. Found three coolant leaks. One from the line that goes from the water pump to the cylinder head spout (no big deal). One from where the thermostat screws in (also no big deal). And one from the front of the head at the head gasket. (no big deal, I didn't use copper head gasket sealer, so I will get some and apply it).
Now. I figured I can try to run it. Started cranking. I could tell right away by the sound of the rain cap on the muffler that the cam was out of time. Next thing I know -- BOOM!. The fuel ignited, and blew the muffler into the ceiling of the garage and onto the floor. Luckily it didn't put it through the sheetrock. So, long story short. I will be pulling everything apart and letting you know how it all goes when I get at it again. Probably won't be until next weekend.
Bob Devol
05-01-2008 18:50:07
 Re: SC Timing-Back to Basics in reply to Ken Christopherson, 04-29-2008 05:43:02
Check your thrust washer behind cam gear- to time correctly gears on cam and crank should be flush on front face with each other. Timing marks should be single punch on crank gear to double punch on cam gear-single punch on cam gear to double punch on goveror gear. Also make sure the cam plunger and spring move freely.
C. Amick
04-29-2008 14:22:35
For some reason, I have had two of these engines apart and never got the cam timed correctly on the first try. Even the machine shop got it wrong. I lined up the double punch marks on the gears with the single punch marks, but still would end up with the cam 180 degrees out of time. I would end up pulling the timing gear off and rotating the engine and putting the timing gear back on. If you place your hand over the carb at the air intake and crank the engine over, is there suction? If there is no suction, you are probably 180 degrees out of time.
Ken Christopherson
04-29-2008 16:22:32
 Re: SC Timing-Back to Basics in reply to C. Amick, 04-29-2008 14:22:35
When I was putting everything back together I posted about my gears because the punch marks on the cam and crank were there but there were none on the governor gear. I was then told to do it by looking at where the valves were at, and pay no attention to the punch marks. Well, that did not work out at all. So, I am going to take it apart, line up the punch on the cam and crank, then crank the motor over and wait for #1 to be on top dead center of the compression stroke, then put the governor on at 25 degrees (just as if I were servicing the governor as per the service manual). This seems like the easiest way for me to do it. If anyone has any other suggestions please let me know. I am going to try to tear everything apart tonight or Thursday night that way I can get everything back together with RTV gasket maker (I am not going to buy another set of engine gaskets) and let it cure all weekend. Any pointers please let me know! Thanks everyone for all your help!
C. Amick
04-29-2008 18:27:59
 Re: SC Timing-Back to Basics in reply to Ken Christopherson, 04-29-2008 16:22:32
The correct position of the governor gear is dependent upon the magneto position and can be easily changed without removing the timing cover. If the cam is out of time, you have two choices. Pull the cam gear off or drop the oil pan and loosen the main bearings just enough to get the crankshaft gear to drop down. On one tractor, I used a steering wheel type puller to pull the cam gear off so that I wouldn't have to drop the oil pan. Be careful, this gear is easily broken. On another tractor, I removed the oil pan. I wanted to make sure I had the timing correct before reinstalling the oil pan so I ran a short hose from the oil pump to a can with oil in it sitting up close to the bottom of the engine. I then started and ran the engine for a short period with no oil pan. It makes a mess on the garage floor but sure beats having to keep removing the oil pan.
Larry59
04-29-2008 06:09:12
I bet blowing that muffler off woke you up some. :)
I had this can over my muffler when I firsts got my tractor. Was standing down beside it and reached over and turn the key on. That can blew up and with a loud noise. LOL I was ducking cause I did not know what had happen. lol Watch out for it these days. ha ha ha Good luck on your tractor.
