Will a VAC Case Motor fit in a 310 Case Dozer?
rjacksonky
04-28-2008 16:38:23
A friend of mine has a Case 310 Dozer that needs an engine. He has a running VAC Case tractor and was wondering if the VAC motor was the same as the 310 Case motor? He said the bolt pattern and motors look the same and would like to put the VAC motor in the 310 Dozer.
Thanks.
TimBinWV
04-28-2008 17:50:55
 Re: Will a VAC Case Motor fit in a 310 Case Dozer? in reply to rjacksonky, 04-28-2008 16:38:23
It will fit,but you'll be seriously under-powered. The VAC has a 124 cu inch engine,and the 310 dozer has a 148 cu inch. You'd be better off trading the VAC for a 148 engine,if you can.Depends on wether or not the VAC has the contenintal engine,too. 201 combine engine may fit,as I've seen guys here tell of having one in a VAC for a puller. Good luck with it!
