what to do next.....
tooltime
04-28-2008 11:32:07
the front wheels on my 1950 case dc (wide front) is solid cast, and has 3-bolt hub. i removed the 3-wheel bolts and i cannot get the wheel to free up from hub. i tryed soaking with pb oil no luck. should i heat up cast? any help appreciated. Thanks, JIM
grapefarmer
05-02-2008 14:26:55
 Re: what to do next..... in reply to tooltime, 04-28-2008 11:32:07
You will have to unbolt the flange from the back of the hub because the rear bearing is stuck to the spindle. It a pain to undo the flange as most likely the little bolts are frozen.
Good luck
-Dave
garytomaszewski
04-28-2008 16:21:34
Wooden wedge between spindle and wheel, get it tight then sledge inside of wheel 180 degrees from wedge.
j Heitkemper
04-28-2008 15:35:06
Pry bar it loose ,, oil the hub ,, Put the lug nuts back on within a eighth inch of tight Find a 2nd gear or slower tinker job with lots of turning , and watch those front wheels , It will Come LOOSE when You least expect , Best wishes Jim
tooltime
04-28-2008 12:47:22
thanks for the advice, i will keep working at it. ill try the pry bar thing. i hope i dont crack the cast or hurt the hub. Jim
SDLars
04-28-2008 12:02:33
I have used a wide, dull chisel or pry bar of some sort between the hub and wheel (back side). I was able to do it in such a way that I wasn't too scared of breaking the hub. The first time I did it I was surprised at the tight fit; much more than one would expect of a wheel and hub.
Hoss in Me
04-28-2008 11:44:21
Wont turn at all? Heat would be bad for bearings,but may be junk anywho. Hoss
