401 diesel head torque
dowisc
04-28-2008 10:24:17
anyone have the torque specs for 401 diesel head bolts and sequence.
Pat T
04-28-2008 15:42:05
 Re: 401 diesel head torque in reply to dowisc, 04-28-2008 10:24:17
Jim's got it right, but torque the water, intake and exhaust manifolds to the heads BEFORE starting to do the head studs. Also if yours has been apart and back together again more than once pay attention while you're torquing the studs and watch for bolt stretch. If you get one that takes wa-a-a-y more rotation than the rest once you get close to 100 ft-lbs, it's stretching and the only fix is a new stud. Had a couple on mine do that, FWIW. Good luck with it!
Jim From Calif
04-28-2008 15:15:31
third party image
Torque to --100 ft-lbs: Get it hot and re-torque (you will need an offset endwrench to socket adapted to perform the re-torque)
