Synthetic oil in the old CASE?
Greenfrog
04-28-2008 05:43:48
I have not used synthetic oil in anything up to now. Is there any advantage of using it in a 42 CASE SC and a 52 CASE DC?
Any discussion here?
dieseldave56
04-28-2008 15:21:58
 Re: Synthetic oil in the old CASE? in reply to Greenfrog, 04-28-2008 05:43:48
Does synthetic have advantages over dino or conventional oil in your old tractor? My 1951 Case model DI calls for a good grade of SAE straight 30 for summer and 10 for winter. Questions come to mind? Is you tractor used year round? are there dramtic temperature changes in climate? Is your tractor a working tractor ? SAE standards for winter viscosity ratings ( the W next to the numbered viscosity i.e. 10W30 or 30W whiched measured flow ratings at zero degrees) , wasn"t established till 1952. Synthetics are more stable at operating temperatures. The Novack Volatility numbers show that heated dino oil for an hour at 250 degrees will degrade and vaporize the lighter fractions of oil by 25%. The results are sludge and engine damage. The same test show less than 10% degrade for synthetics. Synthetics have advantages over dino oil for temperature stability and resistance to oxidation. Synthetics , as all modern motor oils have degtergents. Diesel motor oil generally has the higher detergent concentration, even over synthetics. Any motor oil you choose will be far improved over the grade originally recommended by the manufacturer in the "50"s. I use a multi weight 10W30 conventional oil (temps here go from -20 to 95 degrees, working temps from 10 to 80 degrees). I change the oil every year or < 250 hours. The extra cost of sythetic is not justified to me. My 2 cents
Walt davies
04-28-2008 10:15:08
When i tore my LA down it was as clean as any new engine I wonder where they find these old tractors with so much sludge in them. I saw these when i was kid but detergent oil has been out since the early 50's and most people have used it for the last 50 to 60 years.
Hey take the valve cover off an look at it. No sludge no probblemo.
Walt
C. Amick
04-28-2008 09:02:14
I think you can use detergent oil of all most any type unless the engine has been ran for years on non-detergent oil and there is significant sludge build up. I have a neighbor who switched from non-detergent oil to detergent oil in the Cockshutt 30. The detergent oil cleaned out the oil sludge and plugged his oil pump screen several times. The engine started burning oil and he had to rebuild it.
buickanddeere
04-28-2008 07:50:09
According to old wive's tales. The machine is going to blowup if modern detergent 15W-40 oil is used and unleaded or low sulfur diesel is used. Go forth, fill with Rottella,relax and tell Bubba the oil expert down at the diner to shut up. You Case was designed to work with the oil ratings of the day which were low tech at best. The main advantage with synthetic here would being able to use thick enough oil to reduce oil consumption. Yet be thin enough to allow cold weather starting.
Leland
04-28-2008 07:24:53
A waste of oil and money ,those things are built so loose to start with and would probley develop leaks everywere since synthetic since it will remove all gunk inside engine probley keeping the thing from leaking to start with , will expose every minor one .just stick with the 30w non detergant oil that has been in then for years before you got them .
