Case 1816
kwikgrizz
04-28-2008 01:49:18
Need some help....I dont know a lot about hydrulics. I am having a proplem with the drive and sterring on the loader. It seems to work better when it is cold (but still not good. After it warms up it doesnt want to move at all. Were should I start looking for the problem? Thanks for any help.
BJM ia
05-20-2008 05:38:08
 Re: Case 1816 in reply to kwikgrizz, 04-28-2008 01:49:18
I have a Case 1816, had the samee problem. I had the dealership change the belts, works fine now. Was well worth the money to fix it!
kwikgrizz
04-30-2008 01:36:35
Well I tried that and it did improve but still not like it should be. After it warms up it doesnt want to move at first start it is sluggish. Any more Ideas? Thanks
mEl
04-28-2008 03:49:25
If it is the older setup the biggest problem with the 1816 that used the hand lever to tighten the drive belts was belt tension, the belts slip and cause exactly the problem you are having. Check the belts as a first troubleshooting step.
