removed head on case dc
tooltime
04-27-2008 06:22:17
i removed head today, i saw what appears to be a very tiny hair line crack between head stud and sleeve hole on # 4 cylinder. the sleeve is fine. also was wondering the top of the pistons have a build up of carbon, should i try remove this carbon now that im in here? and what could i do about that hair line crack. the crack is about 1/2 inch long and very tiny, hard to see almost. thanks Jim
C. Amick
04-28-2008 09:25:43
 Re: removed head on case dc in reply to tooltime, 04-27-2008 06:22:17
I don't think the crack will hurt anything. Did you have any coolant leaks prior to removing the head? Spray the new head gasket with copper spray sealer to help assure a good seal. I would clean the pistons, only if you can do it without getting the loose carbon down into your rings. You might be able to seal the space around your piston off with some cloth and vacuum the loose carbon up as you go?
tooltime
04-28-2008 11:24:45
 Re: removed head on case dc in reply to C. Amick, 04-28-2008 09:25:43
thanks for the help. the head gasket was leaking a bit, just a small leak. so i decided to pull head to replace that gasket. the crack looks more like a surface scratch. im not sure if that was why gasket was leaking. the head gasket that was on there looked pretty old. i ran this tractor for about 2 hours and there was no over heating and tractor ran fine. i think i will just put new gasket on, and see what happens. Jim
C. Amick
04-28-2008 12:40:10
 Re: removed head on case dc in reply to tooltime, 04-28-2008 11:24:45
I guess there is some risk not having the head checked for straightness, but on the other hand head gaskets aren't all that expensive. Did you check the valves and seats? You can turn the head upside down and fill them with gasoline to check for leakage. It's sort of crude, but it tells you if the valves and seats need to be ground.
