not a good day. Need some help
INCase
04-26-2008 20:36:06
getting ready to put the engine back on the 730 and was moving the rear end with another tractor. 2 problems yesterday (among others)
#1:::I didn"t have the bell-housing up high enough and the PTO shaft slid out. When it got to the end of it the weight of the shaft buggered up the end of the clutch shaft (dry clutch). I have the unit off but need a new shaft or assembly. Does anyone have one? I see Case "retired" that. #2::: when I started to move it I noticed the hi-low range shifter was almost sitting on the top of the rear end and moved freely. After I got the rear end in the barn I pulled the cover. With the main shifter out I can see inside and it looks like the shifter hardly goes into the block mounted on the shifter rail. It seems the block is too low like the shifter rail shaft rotated too far to the tractor"s left making it too low for the shifter to engage. I can move it up and down some but it "falls" back down. Is this a matter of simply loosening the block on the rail shaft and re-tightening it in the right/higher position?? Or is there some other problem with the shifter rail? Everything else looks pretty good inside except 1st is ground off a bit. Sorry for the long post. Thanks for the help.
Camboted
04-27-2008 17:18:41
 Re: not a good day. Need some help in reply to INCase, 04-26-2008 20:36:06
If I were you I'd get a good file and see if I could repair the shaft, even a machine shop would be an alternative, they can even weld and re-tool.
Regarding the shifter, try re-setting it, the knobs may be worn and need some rebuilding. LOL!
