Case VAC Clutch pilot bushing
Charlie North
04-26-2008 16:28:57
I cannot find a source for the pilot bushing to fit a 1949 VAC.
Can anyone help?
Thanks
Joe (Wa)
04-26-2008 17:11:12
 Re: Case VAC Clutch pilot bushing in reply to Charlie North, 04-26-2008 16:28:57
The picture on the YT site shows a ball bearing? Perhaps it is just a generic pix but I would check with Chis before you order.
The clutch pilot bearing that is pressed into the crankshaft is a brass bushing. Case p/n is VT3370, cross-ref p/n A30024.
Joe
Charlie North
04-29-2008 15:58:09
 Re: Case VAC Clutch pilot bushing in reply to Joe (Wa), 04-26-2008 17:11:12
Thanks Joe (Wa) and the rest of you.
I had initially contacted my local Case/IH/whatever dealer to look for parts for the VAC and was told that they had no way to get parts that old. (It would seem, that person didn't know what they where talking about.)
I was referred to YT by a farmer friend and ordered the clutch repair parts from YT. The input shaft bushing is not the same as the bearing that is offered by YT.
Using Joe (Wa)'s cross reference number, the local dealer was able to order the bushing for me.
Thanks again for your help.
Hoss in Me
04-26-2008 17:06:06
NAPA has them up my way. Latah,Hoss
mEl
04-26-2008 17:02:04
You evidently did not check with a CaseIH dealer, they are available and the same as many later models. I just got one for a VAC tractor project of ours.
Vaughan
04-26-2008 16:54:57
It is available from this site, Yesterdays Tractors. The information listed at the link found below is: Pilot Bearing - For Model: VAC. (Part No: 508051)
Vaughan in Virginia
http://www.ytmag.com/cgi-bin/store/model_parts.cgi?SearchArea=CASE&&md=VAC&cat=Clutch&r=mcats
