730 rolls when parked in gear
mycaseneedspaint
04-26-2008 11:33:41
I've owned my diesel 730 for about a year. It is not a CK, but it is a COM. Everything works great, except...When I park it, in gear, it still rolls. I need to set the brake, or chock the wheels. Is this normal, and if not, what could be wrong? Thanks.
mycaseneedspaint
04-26-2008 17:49:02
 Re: 730 rolls when parked in gear in reply to mycaseneedspaint, 04-26-2008 11:33:41
Thanks.
Gary Smith
04-26-2008 12:28:32
I own 5 tractors with COM drive including a 730 and they all work the same way as yours does. The engine needs to be running to build hydraulic preasure for the clutch to operate. Your clutch pedal is nothing more than a hydraulic valve which is either open or closed. I have farmed with a COM tractor since 1959. When a person learns how to operate them propertly it is a great system.
Gary
comfortking
04-26-2008 12:11:48
COM will roll in gear when shut off. You have a converter in there just like you auto trans in your car, it will not hold in neutral either. You must set the brakes.
