brake parts for case dc
tooltime
04-26-2008 06:25:03
can you still get the necessary parts/ liners ect. to repair brakes on a 1950 case dc tractor? thanks jim
C. Amick
04-26-2008 12:12:13
 Re: brake parts for case dc in reply to tooltime, 04-26-2008 06:25:03
John Saeli sells brake linings and rivet sets ([email protected]). I think Don L. also carries some brake parts ([email protected]). I bought a generic bag of assorted automobile drum brake parts at NAPA and was able to use some of the pins and springs. I ordered new hardened stainless steel balls from McMaster Carr.
Dalton S.
04-26-2008 07:28:27
I just got linigs, rivets, and the seals for my 1951 Case DC about 2 months ago at a local Case IH dealer. Be prepared to spend quite a bit of money though. One lining cost $37.86 and just one rivet cost $1.36. Add that up for 4 linings and 36 rivets, you just spent $205.88 not including tax. I would probably replace the brake seals while you have it apart. Those cost $19.10 a piece. Add all of that up, and you have over $250 into it. If you do replace the brake seals, drain ALL of the rear end oil. If you dont, it will all come out, about 10 gallons of it, once you unbolt it from the transmission housing. I found this out the hard way. Luckily enough I had a couple 5 gallon pails not to far away from me.
