case DC radiator engine drains
tooltime
04-25-2008 09:42:34
where are the radiator and engine block drains located on a case dc tractor . thanks , Jim
garytomaszewski
04-25-2008 11:34:53
 Re: case DC radiator engine drains in reply to tooltime, 04-25-2008 09:42:34
Ther are no block drains, it drains through radiator drain. The radiator drain is on the left hand (sitting in seat facing forward, as all left/right references are) side in line with lower hose. There might be a 1/2" pipe extension through the frame casting in this area other wise there is a hole there that will go to the radiator lower tank and a pipe plug.
tooltime
04-25-2008 16:17:37
 Re: case DC radiator engine drains in reply to garytomaszewski, 04-25-2008 11:34:53
thanks, i will look there. Jim
