case dc with mag/ no dist or coil
tooltime
04-24-2008 20:03:12
can i add a alternator to tractor that has no coil or distributor. i can only hand crank start tractor right now. the generator did not come with this tractor when i bought it. i assume they had a 12 volt system converted at one time. there is a starter on the tractor and a selonoid, but no wires to anything including lights. i have to shut tractor off by grounding wire that comes out of mag. im new to tractor mechanics , but sure would like to learn it better. Jim
El Toro
04-26-2008 12:56:11
 Re: case dc with mag/ no dist or coil in reply to tooltime, 04-24-2008 20:03:12
Your alternator would keep the battery charged so you could use the starter and be able to use your lights. You need to have a wiring diagram and I'm sure someone on here has one. You're going to need new battery cables and a 12 volt battery.
Hal
old
04-24-2008 22:22:06
Well since it has a mag sure but even if it had a distributor you could also do it. A mag works independently of a battery system and needs no battery power to work. So yes you can put an alternator on it but DO NOT hook up power in any way to the mag or you will destroy the mag
ihc49
04-24-2008 22:13:47
this tractor is 6v.it should have a push pull switch for shut off by grounding mag.either get a 6v gen. or to convert to 12v theres a wiring diagram on the first page of farmall site for alt. hook up. myself i keep everything 6v. and original.in the restoration dept. originality counts.
tooltime
04-25-2008 05:55:24
 Re: case dc with mag/ no dist or coil in reply to ihc49, 04-24-2008 22:13:47
thanks guys, i will consider all you say. Jim i cant wait to get this case tractor up and running.Jim
