Case CC - Cleaning the Tranny case out
Fred in Utah
04-24-2008 18:44:45
I plan on cleaning the crap out of my cc's tranny this weekend (oil and accumulated dirt). Does anybody have any reccomendations on the best way to do this? Where is the best access point? -- good access and minimal harm to gasgets. What is the best solvent to use? How to get the "gunk" out?
Thanks for the help
Fred
mshultz
04-25-2008 05:53:11
 Re: Case CC - Cleaning the Tranny case out in reply to Fred in Utah, 04-24-2008 18:44:45
I just did this last weekend to mine. To do a good job, you'll need to remove the top tranny cover and the rear cover. I drained mine and had the plug out for about 3 weeks - thought it was pretty well empty. Then I removed the rear cover and there was well over an inch of sludge down there. I out on some rubber gloves, and ended up pulling out over a gallon more of sludgy stuff. I also found 2 pieces from the stearing worm gear in the bottom. You can get about 80% of it from the back, but unless your arm is longer and more flexible than mine, there is no good way to get the front section cleaned out where your gears actually slide when shifting. Even with the top cover off, I'm not sure that I got everything out. I suppose of you could somehow flush some fluid around in there somehow you might be able to get most of it from the rear, but I didn't have a way to do that.
Good reliable case guy told me not to bother with replacing the gaskets when putting the covers back on - just get them cleaned up good and apply some gasket sealer. My entire engine was done that way, and after 3 years I have no leaks.
Good luck!
Fred in UT
04-25-2008 07:47:14
 Re: Case CC - Cleaning the Tranny case out in reply to mshultz, 04-25-2008 05:53:11
I will let you know how it goes
Tom Railsback
04-25-2008 07:12:14
I just cleaned the transmission case on my 1952 "D". I drained it and then put in 5 gallons of off road diesel fuel, drove it up and down the alley for about 10 minutes, drained it again, and put in $100.00 worth of 80-90 gear lube.
wilson
04-26-2008 07:48:16
 Re: Case CC - Cleaning the Tranny case out in reply to Tom Railsback, 04-25-2008 07:12:14
now daggone it tom I drove that fine dc for the 10 min while you either snoozed or was on computer. Any how frllows if you"all get the chance visit tom and see all the old case stuff in the area.
