wiring diagram for 1950 case dc 12 volt
tooltime
04-23-2008 19:54:34
what is a good alternator to use , and if there is any wiring diagram available. tractor has head lights, starter, no alternator, and wiring for headlights, switch, selonoid are all gone. I can hand crank start tractor, but key start would be nice. Thanks for any help, Jim
grapefarmer
04-25-2008 10:23:31
 Re: wiring diagram for 1950 case dc 12 volt in reply to tooltime, 04-23-2008 19:54:34
Also you can get a 5/8 wide pulley to match the pulley size on the case DC,from speedwaymotors.com. I got the aluminum one for the old 1969 chevy 10DN externally regulated alternator I had laying around. I then bought an electronic regulator off ebay which bolts to outside of the alternator
Pulley can be found at:
Link
regulator:
http://cgi.ebay.com/ebaymotors/Regulator-Conversion-for-Delco-10DN-12volt-Alternators_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ33573QQihZ005QQitemZ150231048470QQrdZ1QQsspagenameZWD1V
Walt davies
04-24-2008 14:12:11
You can get late 60's chevy truck generators that are 12 volt and they fit pretty good. also look original.
Walt
Larry59
04-23-2008 21:13:43
I just converted my Case over from generator to alternator. I went to parts place and bought one for a 1975 chev 10 and it's a three wire. Now don't forget while there to get a plug for the alternator! They sale them and you will need it to plug into alternator.... This alternator is small and works good. Tell them you want this alternator for this truck with no power. Otherwise you get a big one and not the smaller one. My cost was $35.00 for alternator and the wire plug for alternator was 2.99 here in Missouri at 'O' Reilly auto parts.
I next got a long bolt that fits where generator was holding. Goes from front to back. Put in a spacer such as a small pipe that fits around the bolt to take up any room left there.
Next stop at Radio Shack and get a Rectifier Diodes. Comes in package and cost of about $2.50 here. You will only need one in package but save the rest.
Now if you send me your email to [email protected] and put in subject line. Tractor Alternator. I will send you a diagram and more information on how to hook it up.
tooltime
04-24-2008 05:04:09
 Re: wiring diagram for 1950 case dc 12 volt in reply to Larry59, 04-23-2008 21:13:43
Thanks for all your help, my email is [email protected]
Larry59
04-24-2008 05:58:24
 Sent it this morning 7:45 am Thursday in reply to tooltime, 04-24-2008 05:04:09
Just mailed it off to you this morning. It is in picture form and jpg formated. Hope it is big enough for you to see. You might want to enlarge it if needed. Information on email letter to you also.
tooltime
04-24-2008 10:11:56
 Re: Sent it this morning 7:45 am Thursday in reply to Larry59, 04-24-2008 05:58:24
Thanks Larry, its a big help! Jim
