Case 442 Hydraulic Pump
RoseMandy
04-23-2008 13:20:46
My husband has been tinkering for a year with an old Case 442 garden tractor trying to find out why it runs so doggone slow. Now he believes it may be because the previous owner replaced the hydraulic pump and put in the wrong pump. His question is: if he puts in a new pump should it be a high-volume/low-pressure pump or a low-volume/high-pressure pump?
RoseMandy
04-27-2008 08:39:52
 Re: Case 442 Hydraulic Pump in reply to RoseMandy, 04-23-2008 13:20:46
Question: New hydraulic pumps are priced way out of my cookie jar funds. Would a used hydraulic pump removed from a Case/Ingersoll Model 222, serial 14069630, 1985 year, work for my Case 442 garden tractor? Thanks. Bill
Klyde
04-23-2008 20:32:00
442 was around 8GPM and not over 2000 psi. The biggest mistake people make is using hydraulic oil instead of the 15w-40 the system was designed for.
