Eagle Hitch Conversion
ChrisOntario
04-23-2008 12:32:53
This message is a reply to an archived post by mj on December 22, 2003 at 19:13:47.
The original subject was "Eagle Hitch Conversion".
Thank link doesn't work anymore. Does anyone have it? I need to see if conversion from the Eagle hitch to 3pt is possible for us.
Having a VERY hard time finding a belly mower that will suit. No dealers in my area have one.
ChrisOntario
(Ottawa/Williamsburg)
Jim McVay
04-23-2008 18:21:35
 Re: Eagle Hitch Conversion in reply to ChrisOntario, 04-23-2008 12:32:53
You would need a pair of lower link arms with balls on both ends. You would need to change the way the lower links attach to the tractor. The 3 pt lift arms are narrower. You with have to make a new set of links to upper arms with a side to side swivel additionally and and adjustment on one side. You will also have to make some sort of sway limiter also.
