Shift problems on 58 case H-D-L area
Larry59
04-23-2008 05:29:00
I just recently had a new clutch installed so I know that is not my problem. But my tractor is a 58 case thriple range tranny. The regular shift of 4 speed works fine. But the High-Drive-Low shifter does not want to shift for me! I may be doing something wrong when trying to shift ..I don't know. I have pushed clutch in and with tractor in regular gear and it won't shift. I have tried out of regular gear. Clutch in and clutch not in. Any idea's what I am doing wrong here? Thanks
Larry59
04-23-2008 19:11:24
 What it is not doing ??? in reply to Larry59, 04-23-2008 05:29:00
I can shift the regular shifter in to each gear. This being the four speed. But the "range shifter of D-h-L " is in D at this time and I can not get it out of it. Won't go into the neutral. When working - In neutral you then have to pull it out some to right to get it into L which I need for the bush hog.
Jim McVay
04-23-2008 18:14:08
 Re: Shift problems on 58 case H-D-L area in reply to Larry59, 04-23-2008 05:29:00
I would say when you reinstalled the shift cover you did not get the shifting forks in the right place.
old
04-23-2008 21:16:13
 Re: Shift problems on 58 case H-D-L area in reply to Jim McVay, 04-23-2008 18:14:08
Shifter cover has not been removed I know because I was the one who installed the clutch.
bradley martin
04-23-2008 18:13:56
I doubt that it is something that you are doing wrong. Assuming that you mean that you cannot move the shifter, my first thought would be a problem with the forks. Hopefully you can get it into neutral or you will have a big problem pulling the top cover off to assess the problem.If it is ( or you can get it into neutral) I strongly suggest that you pull the lid off now to check out the forks and shift rails.
Eldo case
04-23-2008 06:48:40
What do you mean by won't shift? Gears grind! Shifter won't move! Please explain. Will help to figure out the problem.
JGarner
04-23-2008 06:20:57
Larry, send me your e-mail address. I have scanned the Case service manual that I have for the 350, 500b and 600b. I can send you the Clutch and transmission sections that have the break down with drawings and photos. This could help you diagnose the problem. I couldn't find a "won't shift" line in the trouble shooting guide. My e-mail is on so just answer back.
Jim Garner
