Case 660 Combine
jeffalex
04-23-2008 02:23:57
We are hobby farmers and are putting in about 5 acres of feed corn. A local guy has a Case 660 combine for sale for what seems to be a fair price. He says it works. Are there any quirks with these that we should know about?
Thanks!!
Gortex
04-23-2008 10:36:25
 Re: Case 660 Combine in reply to jeffalex, 04-23-2008 02:23:57
I thought a 3 row head was a bit much for a 660, any thoughts on that?
Thanks
Gortex
bradley martin
04-23-2008 18:07:37
 Re: Case 660 Combine in reply to Gortex, 04-23-2008 10:36:25
The 3 row narrow/2 row wide was what was originally available for the 660 and 960 as Jim B stated. The Case cornheads did not enjoy the best reputation in that era. The 660 itself was/is a great, little combine (little is the operative word here!!) that would likely do your small acreage very well. There were a lot of these machines sold and you should be able to locate most parts needed in salvage yards. However, with the current price of scrap that is rapidly changing.
Jim B
04-23-2008 10:16:20
We have a 660 with both a grain head and 3-row corn head. It's not used much anymore but we like it enough to keep it as a backup to our bigger Case 1160 combine. Here are some comments about our experience with the 660 >>>
The machine with grain head mounted works well in Wheat but not so well in Soybeans. This is because the cutter bar is rigid mounted (non-floating) and alot of beans are missed low to the ground.
With the 3-row corn head mounted there needs to be auxiliary weights added to the rear of the combine to offset the weight of the head. The machine can handle both a 3-row, narrow row (30" spacing) or a 2-row, wide row (40") corn head but is too wide to use a 2-row narrow head.
The snapping rolls on the corn head have a set of knifes mounted to prevent stalk wrapping around the shaft(s). We found these to be unnecessary in our crop conditions and the head ran smoother without them. The corn head typically wears out the front bearings on the snapping rolls quite quickly.
The combine itself is quite fuel efficient compared to the larger machines. Our has a gas engine 4-cylinder, but I understand there was a diesel also available.
The combine has pretty small tires so stay out of the field when it's muddy. My wife still complains about having to wait with the cab-less tow tractor during those long corn harvesting fall days awaiting to pull the combine out of those muddy spots that I always seemed to get too close to !!!!
