Case L questions
patsdeere
04-22-2008 22:12:41
Ok, I have to apologize for the number of questions, but I am stumped.
1. Does some one have a picture of the connector rod that goes from the mag to the pivot pin (for adjusting timing)?
2. What is the best place to start it (in regards to timing)?
3. I have an external oil refiner (about 14" tall, 8" dia). How do you open the darn thing?
4. What do I need to think about when I try and start this beast?
5. How can I assure the thing will die when I want it to? mag kill wire or something else
6. How do I stop the thing once I get it moving since it doesn't seem to have brakes (other than the parking brake)?
7. The flapper in the manifold - where should it be and what does it do (when working right)? When working correctly, how do you make it move (what rod or thing do you move to make it move)? Mine is rusted in an almost horizontal position. Will this cause a problem with starting or running?
8. Can someone give me the measurements for the fenders? Width, where the ridges are, the heighth of the bumps etc.
9. Therre is a little sign on the head and I can't read it all. The first part is: Important Keep cover tight on gasket to prevent dirt & water _____ _____ _____ ___ (unknown words). Can somebody finish the message?
I think that is it - at least for now.
Thanks.
Dave Olson
04-24-2008 17:35:50
 Re: Case L questions in reply to patsdeere, 04-22-2008 22:12:41
4) You should think about what will happen if it is out of time! :(
Here is what happen to the ceiling in my shop when our '38 L Backfired! :oops:
third party image
I store my tractors in an old body shop here in town. The ceiling is about 9' high and all it took was once to make this hole.
third party image
Good luck with your L,
Dave Olson East-Central Illinois[b]
Walt davies
04-24-2008 10:17:12
If your fuel tank has two caps then the flapper is most likely the heater to get the engine up to 200 for distillet fuels.
Walt
patsdeere
04-24-2008 13:25:08
 Re: Case L questions in reply to Walt davies, 04-24-2008 10:17:12
It does have 2 caps. That being the case, do I need to try and unstick it before running the thing? I will only be running gas. Thanks.
Walt davies
04-24-2008 14:08:48
 Re: Case L questions in reply to patsdeere, 04-24-2008 13:25:08
As long as it is open I wouldn't touch it because it most likely will be ruined.
Walt
Steve (DE)
04-23-2008 18:38:42
All the above is true. I have been working on a 1930 L for a few years now. They were so sturdy and lasted so long, that their users had plenty of time to fool around with them. You definitely need a couple of manuals. First, there is an operator's guide which you can find on e-bay, some original and some reprints. Either one will start you on the road to being an informed user. Then, when you get a chance, you need at least one parts manual to give you an idea of what went where and how. The later parts manuals (I think there is an A254 one from 1947 on e-bay now also) give you both what the original parts might have been, as well as later configurations of replacements. Good luck.
L.C.Gray
04-23-2008 17:16:36
7)Yours' is a 29 right? If you're talking about the flapper inside the intake manifold I think you're talking about, thats the butterfly for the governor. On 29 Ls only, the governor was totally seperate from the carburetor and functioned independently as a high rpm limiter only.
The throttle handle was linked directly to the carburetor butterfly and the governor arm was linked directly to the manifold butterfly. Never did the two link together. They realized their mistake rather quickly and changed to the more functional setup of throttle handle linked to governor linked to carburetor to better manage changing loads on the tractor while working.
I'm not sure the divorced governor even made it all the way through the 29 model year, but it was definitely gone by 1930. The divorced governor is one of several hallmarks that make the 1929 very unique from the other Ls.
patsdeere
04-23-2008 20:44:52
 Re: Case L questions in reply to L.C.Gray, 04-23-2008 17:16:36
Actually it is a 31. Which I guess is a good thing by the way you talk about that flapper.
Bobl1958
04-23-2008 13:02:51
Patsdeere - I think I have a couple of owners manuals for the L if you are interested. I also have a very good pair of fenders for one if you need them. You can email me if interested. Bob
Brian in Ohio
04-23-2008 10:18:54
5) I always shut mine off by the mag control level on the steering column, unless I plan to leave the tractor sitting for a long period of time (winter), then I just shut the gas off and let the engine run until the fuel is empty in the carb.
6) The parking brake will stop the tractor.
Tom Railsback
04-23-2008 07:15:56
9) "from entering the engine."
