power beyond
RalphS
04-22-2008 14:08:17
I have a 530CKwith a model23 loader drott 4-way bucket I need a power beyond fitting for the three spool loader valve. Case dealersin my area don't have a listing for this valve. Where do I go now.
Thank you Ralph
West Coast Bob
04-22-2008 15:18:46
 Re: power beyond in reply to RalphS, 04-22-2008 14:08:17
Northern Hydraulics or any other Hydraulic supplier.
From what I understand this Power Beyond port is only a always on pressure port that lets you install another control valve upstream or would it be downstream of the current valve that the hyd pressure comes out of.
What connections does the valve your looking for need to have ?
Just pipe thread or something exotic like a Flat "O" Ring seal ?
Any idea of the Volume, and Pressure that would flow through this hose or pipe to the valve your looking for ?
Maybe check EBAY for a valve that would work.
RalphS
04-22-2008 16:04:45
 Re: power beyond in reply to West Coast Bob, 04-22-2008 15:18:46
The fitting I need is like a short pipe with o rings at both ends threaded on the outer end to match valve body and hose fitting to send high pressure to backhoe. threads on plug in this port now are 1 inch outer part of thread
Ralph
West Coast Bob
04-24-2008 07:43:47
 Re: power beyond in reply to RalphS, 04-22-2008 16:04:45
So this is one inch pipe thread or one inch straight thread ?
Take a picture of this fitting if you can and E Mail or post it here.
Here is a little bit of info about the code you need to post the pics so they appear here. http://tutorials.photobucket.com/tutorial_151.html
