Dc
DonJohn in Minn
04-22-2008 12:18:44
Ijust got a very nice Dc,ser.5305709Dc,it looks like avery faint 3 behind the Dc stamp on the block, no tag on dash. What is the deferance between DC, DC3, Dc4,if any. After reading old posts iguess this is a 49. thanks for any help.
DonJohn in Minnesota
04-23-2008 08:28:38
 Re: Dc in reply to DonJohn in Minnesota, 04-22-2008 12:18:44
With a ser. no. on the block of 5305709 wouldn't this be a 49 thanks, this is only second case I have owned the other was a 580 b const.king.
04-22-2008 19:17:18
My tractor has nonadjustable wide mounted in front of rad.
Tom Railsback
04-22-2008 20:58:27
 Re: Dc in reply to DonJohn in Minnesota, 04-22-2008 19:17:18
That would be a late DC4; it has what is known as the heart shaped front end and was built after Sept. 12, 1952.
Tom Railsback
04-23-2008 13:15:44
 Re: Dc in reply to Tom Railsback, 04-22-2008 20:58:27
It's possible that someone has put a later DC4 front end on your 1949. I was just guessing based on your description since you did not post the serial number in your original post.
Tom Railsback
04-23-2008 13:17:38
 Re: Dc in reply to Tom Railsback, 04-23-2008 13:15:44
More egg on my face; I didn't read the whole thread before posting ab out the serial numbers. A photo would be helpful so we can see shat you have.
04-23-2008 13:51:32
 Re: Dc in reply to Tom Railsback, 04-23-2008 13:17:38
Heart shaped front on older tractor thats what I have thanks Tom.
C. Amick
04-22-2008 16:26:55
A DC-4 has a fixed width wide front axle mounted under the radiator and 38 inch rear tires. A DC-3 has 38 inch rear tires with an adjustable wide front axle mounted in front of the radiator, or a single or dual wheel tricycle front.
