DC-3 Hitch?
dpitdog
04-21-2008 05:49:54
is there anyway to modify a 49 case hitch to take three point implements? mine has the mechanical lift but no hydrolics.
Tom Railsback
04-21-2008 11:36:55
 Re: DC-3 Hitch? in reply to dpitdog, 04-21-2008 05:49:54
I have seen it done, but I'm not sure I can describe it. However, I'll give it a try.
You need two draft arms like those off an 8N Ford.
they should be anchored to the frame the drawbar swings on and connected to the raising bail of the mechanical lift; I'd suggest by a couple short pieces of chain. This would provide your lift.
You also need to fabricate a mount for your toplink or you will only be able to lift the tractor end of the implement.
I have two DC's and a CC I'd like to rig this up on myself, but I'm no welder to fabricate the brackets needed for the front end of the draft arms.
