case what year
rch
04-21-2008 05:40:25
Hey, A buddy of mine pulled a case out of bushes has been setting since 1996 owner says its a case sc serial# 619590sc. Is this a 1956 model? Also we got engine to turn over but will lock up after a few turns, will drop oil pan this week any suggestion on what to look for.This is first case we have worked own.
JGarner
04-22-2008 05:59:21
 Re: case what year in reply to rch, 04-21-2008 05:40:25
Further to Tom's comments. If it has an eagle hitch 3pt and hand clutch on the left side its a 1952 model. 1952 was the first year for eagle hitch on the SC and DC. In 53 the left side hand clutch went a foot clutch.
Jim
rch
04-21-2008 09:41:20
Thanks went over and checked serial# again there is a 5 at the start so that make it a 1952.Will be weekend before we can get back to tractor will check values also could be acorns because tractor was under oak tree in weeds.A tree limb had fallen on tractor during hurricane Fran but just bent seat and fender been sitting there sent 1996.
Thanks,
Curt
C. Amick
04-21-2008 09:14:03
Could be a stuck valve causing the lock up as mentioned below or mice could have carried hickory nuts into the top of the cylinder. The serial number should be on the edge of the engine flange where it meets the bell housing. Left side I think.
Paul f
04-21-2008 06:34:02
Also look for the number stamped on the flange at the rear of the motor on the left side
Tom Railsback
04-21-2008 06:28:49
Serial number is probably 5619590 which would make it a 1952 model; could be 4619590 which is a 1942.
Look at tag again; the first digit is probably obscured by the head of a stove bolt.
It sounds like it could have a valve that's sticking.
